It is currently Thu Aug 14, 2025 3:07 pm
 Post subject: Resizing pipette tips
PostPosted: Tue Aug 11, 2015 12:39 pm
I need to skinny-down some pipette tips for squeezing CA into fret slots. I know Todd Stock had a tutorial on this subject, but his input has been removed. Anyone remember how to do it?
Max
Max Bishop
Brighton, Michigan
PostPosted: Tue Aug 11, 2015 1:38 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
I just pull the tip with pliers until it stretches out enough to narrow it the amount I want, and snip the end with scissors. I've done it with my fingers, as well, but better control with the pliers.
Alex
These users thanked the author Alex Kleon for the post: jack (Tue Aug 11, 2015 1:57 pm)
PostPosted: Tue Aug 11, 2015 2:03 pm
Thanks, Alex.
Max
Max Bishop
Brighton, Michigan
PostPosted: Tue Aug 11, 2015 3:03 pm
Last Name: Smith
City: Graton
Zip/Postal Code: 95444
I heat mine with a lighter. Then they pull easy.
Michael F Smith
Goat Rock Ukulele
http://goatrockukulele.com
PostPosted: Tue Aug 11, 2015 7:54 pm
Every time I try it, it just breaks! [headinwall] [headinwall] [headinwall]
PostPosted: Wed Aug 12, 2015 6:21 am
First name: Alex
Last Name: Kleon
City: Whitby
I usually hold the tip between my fingers for a few seconds first. Maybe putting the tip in some hot water would work better.
Alex
PostPosted: Wed Aug 12, 2015 9:22 am
First name: Frank
Last Name: Ford
City: Palo Alto
Zip/Postal Code: 94301
Step A:
BITE
Step B:
PULL
Step C: Snip to length.
Takes a second or two - works every time. . .
Cheers,
Frank Ford
FRETS.COM
HomeShopTech
FRETS.NET
These users thanked the author Frank Ford for the post (total 3): JSDenvir (Wed Aug 12, 2015 8:08 pm) • Alex Kleon (Wed Aug 12, 2015 11:26 am) • Mark Fogleman (Wed Aug 12, 2015 11:07 am)
PostPosted: Wed Aug 12, 2015 11:37 am
Thanks to all for the input.
Max
Max Bishop
Brighton, Michigan
PostPosted: Wed Aug 12, 2015 2:26 pm
Frank!!! That's awesome!!!
PostPosted: Wed Aug 12, 2015 8:23 pm
I think the ability to cold stretch these depends on the type of plastic used. Mine, like Waddy's, just break. I usually heat them with a lighter about 1/2" from the tip until the plastic becomes clear. From there you can sketch it for a particular length or diameter depending on what your application is.
Matt Jacobs
"Don't tase me bro"
